Connecting speakers (logitech Z5500 5.1) and headset (Steelseries 840, optical)
Crasje
Hi All,
I currently have a headset that is looped via my speakers, so whenever I turn it on. My speakers are automatically off.
What is the best way to connect this? Speakers on the motherboard, headset too via optical and when you want to switch change the default player in W10?
or
go with optical from the motherboard to Steelseries 840, that also has an optical out and loop that to my speakers.
or?
Suggestions are welcome!
Corsair 3500x
Corsair HX1200i
Asus ROG Maximus Z690 Extreme
Intel Core i9-12.900k
Corsair H150i Elite Elite LCD XT
Corsair DDR5 Dominator Platinum RGB 2x32GB 5600Mhz
Samsung 980 PRO 2TB M.2 SSD (2x)
ROG RTX3080-O10G-Gaming
Monitor 1: ASUS ROG Swift PG34WCDMC
Monitor 2: ROG Swift OLED PG27AQDM
ROG Strix Scope II 96 Wireless
ROG Spatha X
Windows 11
xeromist
I have an Astro setup, but same idea. Optical to the headphone amp then optical from the headphone amp to the speakers. Works great. I just turn the speakers down when I want to use the headphones.
Whats an astro setup?
On the Steelseries you have this little management console, perhaps there you can configure the output, either optical or speakers?
Corsair 3500x
Corsair HX1200i
ROG Spatha X
Windows 11
xeromist
Astro Gaming makes audio equipment for gamers. I have an older discontinued wireless mixamp from them but it works similar to some of their current models. No management console but similarly it has optical in and out so I use it as a passthrough on the way to the speakers.
http://www.astrogaming.com/shop/
It's really not a big deal as the volume control for my speakers is within arm's reach. I'd rather just turn a knob than have to use a console to switch outputs.
