Connect and sync gpu to aura - ARGB
c64
47.5 billion transistors and I want to connect 3 wires from two products that do the same thing so they are in sync. Doesn't matter if I can't do it, ie it's no big deal. I won't have a tantrum or see how far I can fling my dummy, i promise. But after some searching and reading, it seems some cards aren't supported while others, at least, maybe asus cards, are.
System :
14700k with huge non argb heatsink and fan. I forget the brand atm
ASUS B760 - PLUS
64 GB ram with no ARGB (corsair) - I nearly bought the ARGB stuff too
Gainward RTX 4060ti - with seemingly only white colour allowed via expertool2 on GEFORCE light on top
GAMEMAX Black Diamond ARGB case
Mobo to fan ARGB control is perfect, just want to add on the GPU light.
4 REPLIES 4
Nate152
c64
No, no lead. I can get or make one (I have a couple argb leads here) but I don't know where it is supposed to plug in lol
my 4060ti isn't on the supported list under that guide
