I'm currently in the R&D phase of my build. can you guys tell me if these parts will work together and what to look for?
CASE - Corsair 600T (black)
RAM - Corsair Dominator Platinum, 32GB, 2400
PSU - Corsair AX1200i
MB - Asus ROG Maximus VI Formula
SSD - Asus Raidr
GPU - Asus ROG Poseidon GTX 780 x 2 in SLI (after release)
DVD - Asus External Drive (any suggestions?)
FAN CONTROL - Asus Front Based Gaming Panel (after realease)
CPU - Intel 4770K Haswell (1150)
WATER COOLING
RES / PUMP - Koolance RP - 452x2 dual bay reservoir / pump
CPU WATER BLOCK - Koolance CPU - 380I
FITTINGS by Koolance
240 mm radiator to cool the GPU's and a 120 mm radiator to cool the CPU and MB
RAM COOLING - Corsair Airflow Pro fans with Dynamic Temp and Activity display
what do you guys think.? any and all tips/advice will be appreciated.. Thanks
