Compatible EKWB for EVGA GTX 980 Ti P/N 06G-P4-4996-KR
jacks0n
Im watercooling a pair of EVGA GTX 980 Ti's and had purchased 2 EK-FC980 GTX Ti WF3 waterblocks not realizing how many variations there are for this GPU config. I have disassembled the graphics card and started to add the water block but it is very different and does not clear at either end so I went back to check on EK's site and they do not have a version listed as compatible for that P/N, there are 5 other P/N's from 4990-4995 but no 4996? The 4995 listed uses Titan WB and Back Plates? and looks identical in the picture. Does anyone know if the Titan block is compatible with this version (4996)?:(
4 REPLIES 4
kkn
Level 14
if i was you i would mail EKWB and ask them.
Nate152
Hi Jackson, welcome to the ROG forum !
You must have the EVGA FTW ACX 2.0 980 Ti gpu's, I see the 4996 P/N in the EKWB cooling configurator.
57144
xarot
Level 11
Hmm...you have bought 'WF3' waterblocks? Those are for Gigabyte cards.
There is no fullcover waterblock available for that card. Only universal block.
https://www.ekwb.com/configurator/ <-- use this to select your graphics card and P/N from the list.
Main: i9-10980XE - Rampage VI Extreme Encore - 64 GB G.Skill Trident Z Royal 3600 CL16 - Strix RTX 3090 - Phanteks Enthoo Primo - Corsair AX1500i - Samsung 960 PRO 1 TB + Intel 600P 1TB - Water cooling
HTPC: i7-6950X - X99-M WS - 32 GB G.Skill RipjawsV DDR4-2400 - GTX1050TI - Bitfenix Pandora - Corsair AX860 - Intel 750 400 GB + Samsung 1 TB 850 EVO
All around: i9-7980XE - Rampage VI Extreme - 64 GB G.Skill 4000 CL18-19-19-39 - Strix RTX3090 - Phanteks P500A - Samsung 960 EVO 512 GB - Water cooling
kkn
Level 14
you can buy waterblocks from evga too as long as it is made for the card u have.
