New user here. Casual gamer, some recent (usually, I play them 1-1.5 years after release) games, some way old with mods (currently replaying Warcraft III, intend to play Startcraft Legacy of the Void sometime around 2018 when it's released
I'd like help choosing the right motherboard, it's the only part I am undecided on.
Budget: N/A (both boards have similar price with a 10$ difference)
Main uses of intended build: Gaming, web, Youtube
Parts required: Motherboard
Previous build information (list details of parts): Asus Sabertooth 990FX (v 1.0); Soundblaster Recon3D Fatal1ty; MSI TwinFrz Radeon HD 7950 (1 for now, maybe 2; AMD FX 8-Core Black Edition 8120; Corsair Dominator Platinum 16gb 1866mhz (CMD16GX3M2A1866C9); Antec SG-650w power supply; Zalman CNPS9900DF (dual fan quiet); D-Link DWA-556 XTreme N wireless adapter (I'm waiting on my 802.11ac to arrive); Western Digital Black 4TB (WD4003FZEX; OCZ Vertex 4 256GB, DELL/Alienware OptX AW2310 (x1 for now, x2 soon)
Monitor resolution: 1920x1080, currently on one monitor, soon on 2.
Storage requirements: N/A, already have what I need
Will you be overclocking: yes, in the future (1-1.5 years)
Any motherboard requirements (no. of USB, Xfire/SLI, fan headers): At least 4 USB 3.0 ports, preferably 2 on front, two on back.
Extra information about desired system: Intel Core i5 4670k Unlocked quad core, I keep all my other parts.
So, as you see, I'm leaving AMD and going Intel.
I keep all my parts, except CPU + MB, I'm reusing them in an older computer.
I have narrowed it down to 2 motherboards: Asus Maximus VII Hero, Asus Z97 Pro (Wi-Fi ac), I would like some help in choosing the right one, please.
I intend to, eventually (not right now), overclock it, maybe change my entire rig for a liquid based cooling system, but that's for a distant future (2 years). Right now, I'm quite satisfied with my Zalman CPU fan, unless Intel CPUs generate way more heat than AMDs? I haven't bought an Intel based computer for a very long while now (10+ years), so, I'm kinda out of the loop when it comes to the newer Intel stuff.
I am leaning toward the Maximus VII Hero, but I'm concerned about the sound card. In the past (Crosshair), the sound card was pretty inferior to a dedicated Soundblaster alternative, and also, it caused compatibility problems in many games, not detecting 3D/surround audio at all. I suppose these problems have been fixed now, with all games using Directsound instead of proprietary codecs?
If had no sound card, I would buy this board for sure. But since I already have a good Soundblaster, I'm wondering if I'm making the right choice. The integrated Wi-fi ac adapter in the Z97-Pro is interesting as I currently have not received my Netgear adapter (b.o.).
Thunderbolt is of really no use to me, I don't copy files that often over USB, so even if the extra speed would be nice, I'm not willing to fork over 100 more dollars for the few times I will use this.
So, to make it short, I need to get an answer on this from more knowledgeable people than me:
- Board for board, wich would give the most performance, all things being equal? I suspect the differences would not be noticeable...
- Wich board would offer the most options to overclock it, when I decide it is the time for this?
- Traditionnaly, wich line would receive the more frequent BIOS updates and be compatible with a newer processor in 2-2.5years?
- Is the Supreme FX 2014 a better sound card than my Soundblaster Recon3D for gaming and listening to music videos (Youtube only, I use my Home Theater for CDs)?
- If I don't like the Supreme FX, can I replace it with my Soundblaster Recond3D or will it refuse to work?
- Can both cards be placed concurrently inside the system, and could I use one for high quality headphones and the other one for speakers? Or would they enter into some kind of conflict?
- Did I forget anything in my build, i.e. anything that wouldn't be compatible, would give me any kind of troubles, an insufficient power supply maybe, etc?
Thank you very much.
EDIT: edited for clarification and added a few extra details in the setup of my current rig and some precisions on my future intents.
Windows 8.1 Pro 64bit
Intel Core i5 4670k
AMD Radeon R9 290X (Gigabyte Windforce); Alienware OptX AW2310
Corsair CMD16GX3M2A1866C9 (16gb total)
Asus Maximus VII Hero (Bios v.1104)
OCZ Vertex 4 256gb (firmware 1.5)
WDC WD4003FZEX (WD Caviar black 4TB)
DVD-RAM GH22NS30
Creative SB Recon3D PCIe audi controller
Netgear A6200 WiFi adapter; Asus RT-AC68U (firmware Version:3.0.0.4.376_1663)
