Cases confusion
Arabicuser
Hi again,
I still didn't complete one system even i use one now, but i am now wasting over $3000 because i built 3 computers instead of 1 or 2.
Well, 2 days ago i went to buy few things for my first and second build computers, and i bought one case, but i feel it is not a great one, the problem with it is the water cooling system that it came with, the case is Thermaltake Level 10 GT LCS, the design is not bad and even the case inside is not bad, but i rushed and bought it expensive with water cooling system, i shouldn't go with that, i read some reviews and it shows that the cooling system is not so great, so i don't know what i can do with this case, i don't know if i can return it, but if not then i will use it for my Gigabyte mobo not with my Asus RIVE mobo, then which case i should get?
If i return this case then what i should buy for my first build RIVE and second one Gigabyte? I will keep my Thermaltake Overseer for the third build, or if i buy one cheap for the third then i keep this Overseer for the second one.
Asus Rampage IV Extreme
Intel i7-3930K
Gigabyte Nvidia GTX Titan Windforce
Patriot Viper 32GB[4x 8GB] 2133MHz
H100i
Samsung 840 Pro 256GB 2x
Western Digital Black Caviar 2TB 7200rpm
Corsair AX1200
Cooler Master HAF X
21 REPLIES 21
Arabicuser
An update: I just received a case which is Cooler Master HAF X, from one local shop they sent it by a local delivery courier service, i didn't find many options you people recommended me, and from newegg.com site i see that this HAF X has very good high reviews, so i should be fine happy with it, it is impossible to find one perfect case so i go with one that is one of top rated cases, so now i have 2 cases and this HAF X will be used for my first build, but now i am going to return that Thermaltake Level 10 GT LCS to the shop i bought from and i asked them about another case, they have Thermaltake Armor Revo available, i asked them about TT Chaser MK-I but they said it will take about 3-5 days to be available, so i told them i am ok with Armor Revo, do you think this case is good enough for the third build?
In addition to that case they delivered Gigabyte GTX 650 Ti to use for the third build, so i am very closer to complete all the builds i hope.
Intel i7-3930K
H100i
Corsair AX1200
Cooler Master HAF X
Arabicuser
Finally, i replaced one case i bought with another one, and now i am happy that finally i got 3 cases for my 3 builds, now the last step is to complete the missing components and then start to complete all the three builds as soon as possible, thanks for all help.
Intel i7-3930K
H100i
Corsair AX1200
Cooler Master HAF X
