06-18-2012 12:57 PM - last edited on 03-06-2024 08:29 PM by ROGBot
06-18-2012 01:57 PM
06-18-2012 02:25 PM
Arne Saknussemm wrote:well shop told me mb would fit the case i have like 4 screws not in mb its kinda in the back eg not near the cpu side i think its a full case just back plate for mb is smaller to my asus c v f mb so kinda have a gap at the drive bay end ware the its not fitted down but rest of it solid. Checked if its moving or rubbing and its not so i mite get away with it if not ill swop case as need to go back to shop tomorrow for my cpu. n two sdd drives
The case is microATX or ATX right? Which board are you fitting in it? and how many screws can you fit.....like 6...3 on the left 3 down the middle kind of thing? If you have holes in the motherboard left over but no where to properly fit standoffs you could cut the thread off the standoffs and smooth them and then screw them to the board just so they make sure the board cant flex backwards and contact the case. You'd just have to make sure the board isn't flexed forward.
06-18-2012 05:56 PM
06-23-2012 02:20 PM
Zka17 wrote:Sorry have been away it's the crosshair v
What's your mobo exactly? The thing is that having waterblocks on different parts, it will increase the weight of those components... and that may bend your mobo... which was not designed to be bent... 😞
