I purchased the Cool Master 690 III case. It comes with a Seidon 120V watercooling closed loop system. The case itself has a Side window so it does not have a side fan.
It comes with a 200mm front fan and a 120mm rear fan installed. I plan on placing the Seidon fan/radiator on the top rear aspect of the case.
My question. Do I need an additional 120mm fan for the top or the bottom or both? And which brand would you recommend.
As an FYI if the Seidon is terrible i plan on grabbing the Corsair H100i.
Hero Mobo
EVGA GTX 770
i7 4770k
Seasonic 1000W PSU
i7-4770k @4.2 | EVGA 780ti | Maximus VI Hero | Seasonic 1000W Platinum | Seidon 120v AIO
Trident X 16GB 2400 | Samsung EVO 500GB | Seagate Barracuda 2TB | CM 690 III
Logitech G400 Mouse | G710 Keyboard | Razor gaming headset
ROG Swift pg278q G-Sync Monitor
