04-26-2019 09:26 AM - last edited 3 weeks ago by ROGBot
04-26-2019 09:47 AM
feedmeink wrote:
I'm looking for a case that can support two seperate systems and excessive watercooling options. Considering building a table. Am I bound to two seperate cases?
04-26-2019 12:21 PM
R5Eandme wrote:
Check out this massive case from Thermaltake, model W200. It is designed to house dual water-cooled systems:
https://www.newegg.com/Product/Product.aspx?Item=9SIA8EF5V02665&Description=thermaltake%20dual%20cas...
It has wheels and can stand on the floor, so maybe you won't have to build a table.
04-26-2019 12:26 PM
04-26-2019 01:52 PM
04-27-2019 02:00 PM
04-27-2019 07:10 PM
feedmeink wrote:
Great suggestions! I'll definitely be looking into all these!
04-26-2019 01:03 PM
04-26-2019 01:39 PM
04-26-2019 01:44 PM
