02-15-2018
01:11 AM
- last edited on
03-06-2024
09:18 PM
by
ROGBot
02-16-2018 09:52 AM
02-16-2018 10:41 AM
offthewall69 wrote:
Short answer: yes. The specifics are based on the particular capture card you use, but what you described (gsync monitor to DP, capture card to HDMI) is the preferred method for keeping costs down.
02-16-2018 01:34 PM
02-20-2018 06:54 AM
Korth wrote:
...There is really no way to assign "unused" GPU outputs to video capture in Windows, it can be done with a linux hypervisor and KVM switching or GPU passthrough. There is really no way to avoid putting capture hardware in-line between your GPU and your fancy 165Hz gaming monitor.
02-20-2018 07:07 AM
02-20-2018 07:13 AM
