Can't get RGB to work properly
Vxiajxisbxwivf
Hi folks, im in desperate need of some advice,
Like you can see on the pictures below, from my 5 rgb fans only 3 and one singel LED are lit up, if I try to sync them with aura (which kinda works)
I tried switching Headers and cables, only to find out, that one of the two headers only adresses one LED no matter what.
Mainboard: Asus Rog x570 e gaming
Cpu: Ryzen 7 3800x
Gpu: Nvidia Gtx 980ti
Ram: 32 Gb G.Skill 3600
Fans are all Thermaltake, including AIO and front
If I just plug the fans the other way round, the top looks like the front and the front is fully lit.
I really hope, that someone can identify the problem.
Best regards
Yannick
0 REPLIES 0
