Can I use Samsung 970 Evo 1tb on Rampage VI Extreme?
tinmann840
I have a new build in the works and I'm using a ROG Rampage VI Extreme and all I am left needing is storage plus a few odds and ends like hard tubing, ball valve, fill port, fan splitters and maybe the odd fitting here and there. I've been reading about populated dimm #2 slots not being recognized in bios is the any SSD I should shy away from or is any of the Samsung NVMe compatible?
Inwin 915
Asus Rog Rampage VI X
I7 7820X
G.SKILL TridentZ RGB Series 32GB (4 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200
EK-FB Asus ROG R6E RGB Monoblock
EKWB EK-XTOP Revo D5 RGB PWM Pump, Plexi (Acrylic)
EKWB EK-RES X3 150 RGB Reservoir
EKWB EK-HDC Compression Fitting for EK Rigid Tubing, 16mm OD, Black, 6-Pack x 2
EKWB EK-CoolStream SE 360 Radiator, Slim Triple, Black x 2
EKWB EK-UNI Pump Bracket (120mm Fan)
InWin Aurora Fan Kit Black/White, 3 RGB LED 120mm 2 kits 6 fans total
Inwin Polaris RGB Fan (2-Pack)
ASUS ROG Poseidon GeForce GTX 1080 TI 11GB Platinum
Seasonic Prime Platinum 1300w
I may need a fan controller and a rgb hub and one more Polaris fan for the rear of the case. The reason I didn't go 2080 ti is because I use an Asus pg349q and it only overclocks to 100Hz and 2080 ti is overkill for a 3440x1440 @ 100Hz. I'd appreciate any suggestions I haven't built an new PC in over 5 years. My Rampage V has been rocking steady that long.
0 REPLIES 0
