Can I swap my GTX 780 with a Strix GeForce GTX 1080?
DavTrade
My main system components:
Intel Core i7-4770K 3.5GHz Quad-Core Processor great OC
Asus GeForce GTX 780 3GB DirectCU II Video Card
Asus Maximus VI Formula
Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-1866 Memory
Cooler Master V850 850W 80+ Gold Certified Fully-Modular ATX Power Supply
What are the pros/cons of just swapping the 2 GPU's?
kkn
Level 14
the 1080 kicks the 780's a$$.
when you change it, reinstal the nvidia drivers.
Menthol
Level 14
Pro's
1080 is much faster, more efficient so uses less power and runs cooler, a very good upgrade
Con's
Cost, processor may limit the new GPU but by very little, depends on game and resolution, more so with 2 GPU's
If your using Windows 10, it needs to be version 1151 or newer, or new drivers will not install
Chino
Level 15
