Cable Solutions for Tight Radius
mdawe
Trying to clean up some of the cables that bother in my build. We have a pretty tight radius bend on ROG_STRIX_Z790-A and am looking for suggestions.Cable.jpg
5 REPLIES 5
Nate152
Hello mdawe
That looks ok.
As long as the cables aren't kinked or pinched it will be fine.
I agree with Nate152.  I've had cables like that in the past that had no problems for the life of the motherboard.
But, if you're really worried about it, I think there are longer cables and/or cable extensions that can be bought online.
Have a Good One! 😎
Rooke
Should have clarified. Not worried about kinks or damage more aesthetics. Maybe something like a tight radius bend
Nate152
It doesn't look bad the way it is.
I doubt a 90 degree adapter would look any better, but I do see a 180 degree adapter with a backplate.
This would work, but I'm not sure about clearance with the fans.
There is a Type A and Type B, checking the cpu power connectors for your motherboard, you'd want Type B.
CPU EPS 8 Pin U Turn 180 Degree Angle Adapter with Backplate - MODDIY
Thats not a terrible idea and its cheap
