Cable Braid Query
Chewitt
Hello All,
Just wondering if anyone knew the sizes of Cable Braid needed for each cable (if there are a standard set) i have found guides on the net but none of them actually list the size for instance 2.5mm or 4mm?
CPU - AMD Phenom II 555 OC'd and UCC'd to Phenom II B55 at 3709MHz
RAM - 16GB Kingston HyperX Beast
MoBo - ASRock 890GX Extreme3
GPU - Asus HD 6850 Direct CU
SDD - 240GB Kingston HyperX
ROG RealBench Score = TBB
kkn
Level 14
i would guess 1.5mm, but you can meshure it if you have a psu that you can see the cables tru? ( typos i know... )
Chewitt
i will have to take my PSU apart to measure them, tried the company site and there is no info on their so looks like its exploration time.
