Building my First Rig. HELP!
mikolodean
Budget: 3500 USD
Main uses of intended build: Gaming / Watching bluray and other HD movies / Audiophile
Parts required:
Asus Maximus VI Extreme
Cooler Master Cosmos II Casing
Cooler Master Silent Pro Hybrid 1200W Power Supply Unit
Nvidia GeForce GTX 780Ti
Intel® Core™ i7-4770K Processor (8M Cache, up to 3.90 GHz)
Dominator® Platinum with Corsair Link Connector — 1.5V 16GB Dual/Quad Channel DDR3 Memory Kit
Samsung 840 Pro 256 GB SSD
Previous build information: none. I'm currently using ASUS laptop A42j Model.
Monitor resolution: 1080p and 4k
Storage requirements:SSD (OS/Games) & SATA (Files)
Will you be overclocking: not sure
Any motherboard requirements (no. of USB, Xfire/SLI, fan headers): MAXIMUS VI EXTREME (Future SLI)
Extra information about desired system:
Hi everybody! I would like your opinion and pro help since its my first time building my own rig. My setup was inspired by one of ROG video (http://www.youtube.com/watch?v=grd-ltAm2Gw). So basically, I'm trying to copy it but not the whole thing. Please guide me if I lack something or need something to improve this setup. Im planning to use 1 monitor either 1080p or 4k capable. I plan to buy GTX 780i and upgrade later. Also, wanted to know if this setup will require thermal or liquid cooling or will it survive with just fans? With the said setup, will it last 3-4 years atleast?
Also, any recommendation for a good monitor? Preferably, 4k around 23 - 25 inch.
TIY!
10 REPLIES 10
Antronman
I don't know about the CM PSU, but everything else looks awesome.
The 4770k doesn't fit LGA 2011, so of course the 4930k.
The GPU choice really depends. If you do any programming or 3D renders (like I do) then the TBE is the way to go.
But if all you do is game, then get the 780Ti.
Say hi to the next generation.
Peace is a lie, there is only Passion
Through passion, I gain strength
Through strength, I gain victory
Through victory, my chains are broken
The Republic of Gamers shall free me
