Building my First PC Help me on it
salemzia
Motherboards: RAMPAGE IV BLACK EDITION
storage: Kingston HyperX SSD
case: Level 10 GT LCS 2.0 from thermaltake
Graphics Cards: Gigabyte GeForce GTX 780 Ti 3GB
RAM: G.SKILL OR CORSAIR
Power Supply: EVGA SuperNOVA 1300 G2 1300W 80+ Gold Certified Fully-Modular ATX Power Supply
Sound Card: SOUND BLASTER RECON3D FATAL1TY PROFESSIONAL from creative
CPU: Intel Core i7-3960X Extreme Edition Sandy Bridge-E 3.3GHz (3.9GHz Turbo) LGA 2011 130W Six-Core Desktop Processor BX80619i73960X
Cooling system: Swiftech H320 55.0
35 REPLIES 35
PowerOver9K
First of all. You're not fitting that H320 in that Level 10. Maximum RAD support is 2x120mm RAD. The 320 is 3x120mm. You may want to reconsider the case as Thermaltake's at the moment aren't very good for water cooling. I'm not a TT basher either, I have my old rigs in Armor and Armor+.
Second of all. Go Samsung EVO SSD. Much better SSD than a Kingston.
Are you ever going to put a 2nd or 3rd video card in the rig? If Not, 1300W is overkill. You can go 850W eVGA SuperNOVA G2 Gold (NOT "NEX" SERIES) if you only have one card and 1000W P2 Platinum/G2 Gold if you only have two cards.
You may want to test the on-board sound before you buy a sound card. The sound on board the Rampage is very good.
Mobo: Rampage IV BE | CPU: i7-4930@4.5ghz Hexacore | RAM: 32GB Corsair V-Pro | GPU: 4xR9 290X Quadfire | PSU: eVGA P2 SuperNOVA 1000W\G2 850W | Chassis: NZXT Phantom 820 | Cooling: XSPC Raystorm CPU Block\4xEK 290X Block\2x Laing D5\XSPC Dual Bay Res\Phobya G-Changer 1080 External Rad\Alphacool 140UT60\XSPC AX360 | Fan Con: Lamptron CW611 | Tube: Primochill Adv. LRT Bloodshed Red | 3xCrossover 27" 2560x1440 Monitors | Build Log of Insanity
Sure i will have 2 card so what did you think about cooling ?
PowerOver9K
2 780TI? You need to choose a case first. If you want to use that CPU cooler, look for a case with 3x120mm water cooling radiator support. You might want to look at the Phantek's Enthoo Primo Full Tower.
HappyBuddhaman
I'd go with the G.SKILL for the RAM, Corsairs are awesome, but, IMO, it seems you pay for the name. G.SKILL's are rated excellent and you can get the same speed and timings for a lot less.
Are you doing any overclocking?
No for this time, mabe In the future.
Nuimoa
What are you planning to use your computer for exactly? Just curious 😄
For gaming and my work
PowerOver9K
Are you partial to that Level 10 case or would you be considering to change it per the other parts? What's your case budget?
No problem about the price but i want somthing cool level 10 or check here https://mnpctech.com/mnpctech-case-mod-gallery.html
