Build won't post;/show video
bear2cub
Hello,
Decided to build a computer for a friend and upon completion of build I plug everything in and start it up. DRAM LED turns on, computer stays on for 5 seconds and then shuts off. Here's a list of the build.
F1A75M Pro
AMD A8-3870k
Kingston HyperX Fury 8GB@1600MHz
Rosewill PC case w/ 500W PSU
LG DVD drive
WD Tb HD
Sandisk SSD 240Gb
Do I need to update the BIOS? That's the only thing I can think of. Thank you!
0 REPLIES 0
