Build Advice threads: READ THIS FIRST!
X-ROG
Level 15
Help us to help you by providing the following info.
Copy and Paste this into a new post and fill it out:
Budget:
Main uses of intended build:
Parts required:
Previous build information (list details of parts):
Monitor resolution:
Storage requirements:
Will you be overclocking: yes/no (delete as required)
Any motherboard requirements (no. of USB, Xfire/SLI, fan headers):
Extra information about desired system:
* Budget: This is the big one, so try and be as specific as possible so we don't recommend something you can't afford, or give an upper limit so we can give you a range of options if you'd rather spend less. Remember to state it in your local currency, as it will often buy you more in some countries than others, and we can provide you with relevant links to different online retailers.
* What that budget needs to include. Are you just after a base system? Or do you need to include peripherals such as a keyboard, mouse, speakers and a monitor into your budget. Or are you just looking for a motherboard/CPU/RAM upgrade?
* What the main uses of the PC will be. Different applications (i.e. gaming, video/photo editing, 3D rendering, home theatre/media playback, file servers, web browsing and word processing) will benefit from spending more money in certain areas than others, so this information is extremely useful.
* The spec of your current PC and whether you are re-using any parts from it. This is particularly useful for lower budget builds as you may be able to save money by re-using certain components from a previous system, allowing you to spend more money elsewhere. If you don't currently have a PC, you can obviously ignore this part.
* The native resolution of your monitor. This is the one thing most people neglect to include, but it is very important if your main use will be gaming as it could make the difference between us recommending an £80 graphics card or a £300 graphics card. If you don't have a monitor, say so and we'll recommend based on monitors within your budget.
* Whether you will be overclocking or not. This is quite an important point as many components are recommended based on their overclocking ability (as well as possibly requiring additional expenditure on cooling), but others may be more suited if you are not. If you are unsure of what overclocking is and whether you want to have a go at it or not, have a look at the relevant stickies or try a forum/Google search which will turn up many results. Just remember that it is relatively easy if you are well informed beforehand, and offers a free speed boost (meaning you don't have to buy a more expensive CPU), so is generally recommended around these parts unless you either won't benefit from it or will be using the PC for mission critical work requiring 100% stability.
* How much storage space you require. This is useful for obvious reasons, although we usually recommend allowing for slightly more than you actually need.
* Do you have any special requirements? You may not have even considered these yet, but can be anything from low noise/power requirements, size/space restrictions, watercooling, or any other additional features like fans/fan controllers, wireless cards, RAID cards etc. etc.
16 REPLIES 16
ShortMunchkin
Budget: $1000 aud
Main uses of intended build: intense gaming
Parts required: keyboard, monitor, mouse
Monitor resolution: good resolution for gaming
Storage requirements: loads of storage for movies an games
Any motherboard requirements: emm atleast 4 USB slots and a HDMI slot
Korth
Level 14
This site is a decent price/tech overview, plus useful advice and guidelines as you hover over details. Enough to give you an idea about what you want/need and what you can get for a given price.
[/Korth]
Budget:$750 - $1500USD
Main uses of intended build: Photo/video editing and some gaming; Microsoft apps etc....
Parts required: Everything; this is a brand new build for me
Previous build information (list details of parts): None
Monitor resolution: 1080p
Storage requirements: A LOT....4TB and up
Will you be overclocking: Possible
Any motherboard requirements (no. of USB, Xfire/SLI, fan headers): 3 to 5 USBs; On board video, SLI, WiFi, reliable; easy to upgrade other parts, HDMI
Extra information about desired system: Low noise, spacious for future upgrades; highly considering water cooling in the future
Budget: $2000
Main uses of intended build: Gaming (mostly X-Plane, VR and FPS)
Parts required: Mobo, CPU, RAM (16MB minimum), CPU cooler
Previous build information (list details of parts): ASUS Z77 Sabertooth mobo, i7-3770k, 16Mb RAM, Corsair D800 Obsidian full tower, Corsair GS800, 120mm radiator liquid cpu cooler, 2 SSD's, 5 HDD's, 1 CD/DVD, NVIDIA ROG Strix GEForce GTX1070ti/8GB, Oculus Rift w/2 sensors.
Monitor resolution: 3440 x 1440 (primary display), 1920 x 1080 (secondary).
Storage requirements: Plan to use old drives, but I would like an M.2 that's really fast. Is that the NVME one? Probably 500MB for that.
Will you be overclocking: yes/no (delete as required) Maybe/not sure.
Extra information about desired system: I like the Fractal Design R6 for a new case because all of my drives would fit in it, but I can still use my old 800D if I can figure out how to mount a 240 or 280 radiator on top. I am looking at a i7-8700k and an ASUS Maximus X Hero mobo. Not sure what I want for cooling or RAM, but I would need 16GB minimum for X-Plane.
Any help is greatly appreciated.
AMSI-1
Hi I'm new to the whole forum thing :):) please could any one advise me what intel processor i should get because i do game and do a little bit of work , and my budget is between 100 and 200 hundred pounds…….:eek:
Intel i5 series CPU's would suit your needs
MarshallD3Framp
Another Marshall-- Another Helpful Marshall-- This name has some significance.....
