Build advice - Hero VII & Fractal Design R4
Kajel
2 Questions.
Does anyone know if the Corsair H100i will fit in the roof of the Design R4 with Hero VII? I'm using Corsair Dominator LP ram.
Will the ROG Front Base fit in the Design R4? Does the knob on the Front Base hit the door when closed?
4 REPLIES 4
HiVizMan
Level 40
Have a bump I have never used the case so can not help you.
Actually it does fit but you may have to take some of the stuff off the case itself. I have just seen a whole heap of photo's with the 100 cooler fitted.
Yes the h100i fits with no problem at all.
I know because I have one!
HiVizMan
Level 40
OP rep this man.
Thanks Simon 🙂
Ok great! thanks Simon.
I wasn't sure about the Hero VII with the large VR covers.
