Firstly, let me say i bought build, with less expensive, but replaceable with upgrades, parts. A less expensive motherboard, the ASUS ROG Strix Z370-E... it is a highly competitive motherboard for under $200. :cool:
Specs are in my List. But i will explain in detail.
I bought the Intel Core i3 8100 @3.6Ghz, it is a solid Quad-Core for about $108, and it being a 300 series i can easily upgrade to the i7 8700K that overclock to around 5.0GHz, but the chip lottery is in effect 😕 I am actually planning on getting the i5 8600K instead, it doesn't have Hyper-Threading, but clock speed is the same as 8700K @ 3.6Ghz and Turbo Boost is 4.3Ghz, and it is unlocked, so no need to delid. the i7 8700K is a better choice if you're looking for Extreme Performance, but i am hoping to get the i5 8600K on sale and in a couple years upgrade to the i7 8700K, on sale once again, I'm frugal like that ;).
The case i chose is a very good case for airflow, the Corsair Graphite Series 230T. I chose the Rebel Orange over the black and red, because i had plans to install White and Green Case fans with the top fan slots available to make my PC glow with the Tri-Colors of the Irish Flag.
With the Corsair Graphite 230T there are 2 front 120mm fans, one intake in front up top, recessed from the front panel, and one exhaust in front below it. There is a Dual-120mm/140mm unobstructed perforation section on the top of the case for either dual fans or a AIO radiator fan hook-up. Also has a single 120mm/140mm case fan opening at the bottom-mount PSU , in front of an average 850Wattt PSU, with a removable and washable PSU filter, however since i have the Beast of a PSU, the Antec TPQ 1200, True Power Quattro 1200Watt Fully Modular PSU, it is much too big to fit a fan, but doesn't have problems with wiring or airflow, or install space. The case will also handle 2 GTX1080's in SLI with 4 SSD's and 2 HDD's, also has 2 M.2 installation bays, that will sit under SLI or CrossfireX setups..
I installed a Cooler Master MA620P Twin Tower RGB CPU HeatSinkFan and removed the external fan, after some experimenting with moving the RAM-side fan to the Rear I/O Panel... then i eliminated the External Ram-Side Fan altogether, and still get good cooling from the fan between the Fin-Towers, with the added 120mm top case fans and the rear exhaust fan that comes with the case. I had to move the RAM-side fan to install RAM, slots 2 and 4 are for 2-slot installs, and you will need to install RAM before installing a CM MA620P Twin Tower, and remove the fan.
I then installed 2x 120mm case fans above the CPU Cooler (the Twin Tower CPU HSF almost touches the glass by about 10cm, but looks great because it is in perfect position to shine through the tempered glass panel, no problems installing RGB fans or Addressable fans or RGB Strips, and i have big hands ( I'm 6'1" 176Lbs.)
After installing a 120mm 1300RPM fan of the Dual-120mm/140mm perforations and mounts, top front fan slot, and a 120mm 1600RPM fan in the top rear section, my temperatures have dropped from 32-38 idle, and 45-55 under 98% Load... to 22-24 idle, and 35-37 Under 98% load. I have a PCIe Creative Fatal1ty Champion TruStudio surround card directly beneath the Cooler Master Ma620P CPU Cooler with no problems installing a Chassis Fan 4-pin plug under the CPU cooler and above the PCIe 1x sound card.
Hope this helps anyone looking for a Really High-Performance Build, though i did Sacrifice on the Motherboard (the Z370-E will OC to 5.0+GHz on an i7 8700K, though), Core i3 8100 Quad-Core CPU (it is simply necessary to have a CPU that can handle most games and Music Production Work, and it does pretty well) , the Patriot Viper DDR4 2133 RAM (again, necessary to have 16GB DDR4, and will upgrade in time, speed does count when it's double the MHz, but given that older builds use lower freq. RAM, it seems tro do the trick for a lot less, if that's what you're trying to do.)
The 2x GTX 960's in SLI were accumulated over time, i bought the first one for around $460, and the second one for $240. I am looking to upgrade in the future to an i7 8700K, 64GB G.Skill TridentZ FGB RAM, a GTX 1080 to handle Ultra in Ghost Recon Wildalnds, whose Graphics are so life-like and amazing. I played every Tom Clancy's game there is besides The Division.
And a 1TB SSD would be nice to supplement the TEAM Elite 128GB OS and App SSD i have, though it does make my secondary Caviar Black 7200RPM SATA III HDD work faster.
So my Recommendation:
ASUS ROG MAXIMUS X HERO Z370 or ASUS ROG Strix Z370 Variant
Intel i7 8700K (or i5 8600K), your choice, you can upgrade later)
Cooler Master MA620P Twin Tower RGB CPU HeatSinkFan (it is really easy to remove the RAM-Side fan and install top fans)
G.Skill TridentZ (PC4 32000). At least 16GB
GTX 1080 8GB GDDR5 model, or the GTX 1080 Ti FTW3 GAMING 11GB GDDR5X iCX
Corsair Graphite Series 230T (in black paint with red fans, or Rebel Orange with orange paint and orange fans, bulkier than some mid-towers)
2x 120mm/ 140mm case fans in top perforated mounts {(supports dual 120mm or 140mm Radiator fans for AIO Liquid Coolers)
1x 120mm or 140mm bottom case fan in front of Bottom Mount PSU
CORSAIR RMx Series RM850x
Team Elite 120GB Sold State Drive For OS and Apps (Go larger capacity if desired)
Samsung 860 EVO Series 1TB Solid State Drive SATA III
This will be a Beast PC for Gaming, Video Editing, Games Development, Music Production, You Name It.
