Best PC for 2000$ (US)
superzila
What is the best pc config for 2000$ (US) now?
Play games in high resolution, view movies in Full HD
What would you recommend?
I think:
Video card: geforce 680 or radeon HD 7970
Processor: Intel Core i 7 3770k or i7 4770k
Motherboard: ASUS Maximus V Extreme
RAM: Dont know
HDD: Dont know
SDD: Dont know
Computer case: Maybe Zalman Z11 Plus, Dont know
CPU cooler: dont know
12 REPLIES 12
HiVizMan
Level 40
I assume that is US dollar.
If that is the case no way you can go for the items you have suggested. Just the CPU, motherboard and graphic card are close to 1200.
Do you have a PSU, what resolution do you consider high?
1400 will not buy you to much at todays prices for the top of the range items. 😞
superzila
It is 2000 US dollars
I dont know what mean PSU, my computer resolution is 1920x1080 and i want to play games on ultra high settings
superzila
kkn
Level 14
PSU = powe suply
GPU = graphic card
CPU = prosessor
well ultra high means good graphic cards and they can be expensive.
what online store are you going for? or prefer to get the parts from??
kkn wrote:
PSU = powe suply
GPU = graphic card
CPU = prosessor
ok, I will buy each part separately in the online store.
Which configuration would you recommend?
HiVizMan
Level 40
Intel 4770K CPU
Motherboard Maximus VI Hero
Memory GSkill 2133 16GB (2 x 8GB)
VGA GTX 780
SSD Samsung 840 250GB
PSU 850W
Coolermaster HAF
kkn
Level 14
look at what hiviz sugested, that is new motherboard coming out and the new prosessor, new graphic card ( based on the titan's chip and not on the 6++ series of nvidia )
go to a online store and look up those parts and see what they are gona cost you.
the hero version of motherboard may not be avalible but it is on its way to the stores now.
yes, i didn't see neither Mximus IV Hero no 780 VGA in online Russian stores..
But i see 4770k and it cost like 3770k, i dont see difference between these models
kkn
Level 14
4770 is new, 3770 is older model.
k = unlocked ( for overclocking )
