Best graphics card for around 500 bucks.
Fakesoap
Hey guys,
I am trying to piece together my build and I am stuck on the graphics card. What is the best graphics card I can get for around 500 bucks? Or is it better to crossfire/sli two cheaper ones?
24 REPLIES 24
Fakesoap
Side note: If anyone can help me track down an Antec Dark Fleet DF-85 case it would be greatly appreciated. It's very hard to find since it's been discontinued.
Zka17
Level 16
Welcome to the ROG Forum!
Where are you located? In US you can go onto the Newegg's website, choose the graphics cards and set your price limit… then you can select from there… - between $400 and $500 pretty much they're all good ones…
Also, it depends on what you're gonna use your system… how many onitors and what resolution you will have/will want?
I'm worried about using so much Electric Power / NOISE and HEAT by using 2 Graphic Cards, what recommendations for SINGLE card as POWERFUL or More as 2 cards, in both AMD and NVIDIA , I'll worry about Price Later. I'm not into Video Editing, As long as I can play Crysys 3 w/ALL setting on MAX / Watch Movies and Music I'm Good. Please and Thanks 🙂
if you had a 1.2KW PSU it will not pull that mutch from the wall, it will not pull more then what the system needs.
when on idle it will draw around 2-300ish watt max depending how its set up.
Tokens210
gtx 770's going price lately is about $380, you may be able to swing a 780/ 780ti with $500, if not now then very soon as maxwell was just released and there will probly be a new line rolling out sometime
CoolerMaster HAF 932 Advanced/ Maximus VI Formula/ I7-4770K/Swiftech H320/ Corsair HX850/ G.Skill Trident X (2x8) 16gb 2400MHz/ 2x 840 EVO 120gb(Raid 0)/ WD 1TB HDD (Backup/Storage)/ EVGA GTX 1gb 560 TI/ Asus 12x bluray combo
kkn
Level 14
try and see if you can find the case on enny used online shops or thing like that.
add $20 and you get one of theese -> http://www.amazon.com/EVGA-GeForce-GTX780-SuperClocked-03G-P4-2784-KR/dp/B00CUIVSNS/ref=sr_1_1?s=pc&...
try this page mabye call the number to see if it is avalible from storage -> http://store.antec.com/Product/clearance_items/df-85/0-761345-15238-9.aspx
Antronman
XFX R9 290 Double Dissipation.
Say hi to the next generation.
Peace is a lie, there is only Passion
Through passion, I gain strength
Through strength, I gain victory
Through victory, my chains are broken
The Republic of Gamers shall free me
Chino
Level 15
PowerOver9K
You don't need 1200 watts for two card crossfire/sli. You only need about 1000 if you like a safety net. To answer your question, GeForce 780 gtx. You can swing them for 499
Mobo: Rampage IV BE | CPU: i7-4930@4.5ghz Hexacore | RAM: 32GB Corsair V-Pro | GPU: 4xR9 290X Quadfire | PSU: eVGA P2 SuperNOVA 1000W\G2 850W | Chassis: NZXT Phantom 820 | Cooling: XSPC Raystorm CPU Block\4xEK 290X Block\2x Laing D5\XSPC Dual Bay Res\Phobya G-Changer 1080 External Rad\Alphacool 140UT60\XSPC AX360 | Fan Con: Lamptron CW611 | Tube: Primochill Adv. LRT Bloodshed Red | 3xCrossover 27" 2560x1440 Monitors | Build Log of Insanity
