B550f motherboard cpu cable issue
Scottsull98
Hey all, I’m in the middle of a new build and I have run into a problem.
ive got a rog strix b550f motherboard paired with a rog strix 750w psu.
the psu come with 2 cpu cables that both have 4+4 plugs
the problem is the motherboard takes a 8 pin and 4 pin plug.
i know most people say you can join the 2 4+4 pin plugs together to fit in the 8 pin port but only 1 of the 4 pin plugs fit and the other does not. I’m really stuck with what to do and hopefully someone can help me out here. I’ve added photos to help you understand
kamilahlazott
8-Pin CPU Power Not Detected
  • Some users find that their system doesn't boot because the CPU power cable isn't seated properly. The motherboard requires at least the 8-pin EPS connector, and optionally, a 4-pin connector for additional power.
  • Fix: Ensure that the 8-pin EPS connector is fully inserted into the motherboard. You should hear or feel a click when it's properly secured.
