B550-F motherboard - compatible DRAM ?
HikerLT
Using these components, I can't get the Asus motherboard to boot up to the bios.
I suspect it may be that the DRAM is incompatible ?
On power up The Q-leds will cycle - first on is the DRAM, then CPU, and then stops with both the VGA and BOOT led on. No output to the monitor via the onboard HDMI connection.
AMD Ryzen 9 5900X 12-core, 24-Thread Unlocked Desktop Processor
G.Skill RipJaws V Series BLACK 64GB (4 x 16GB) 288-Pin SDRAM DDR4 3200 (PC4-25600) CL16-18-18-38 1.35V Quad Channel Desktop Memory Model F4-3200C16Q-64GVK
ASUS ROG Strix B550-F Gaming AMD AM4 Zen 3 Ryzen 5000 & 3rd Gen Ryzen ATX Gaming Motherboard (PCIe 4.0, 2.5Gb LAN, BIOS Flashback, HDMI 2.1, Addressable Gen 2 RGB Header and Aura Sync)
Nate152
Hello HikerLT
You will need a dedicated gpu as the 5900x doesn't have integrated graphics.
If you have a dedicated gpu, connect the hdmi cable to it.
