ASUS TUF F15 weird Fan problem
Raysew
Hi,so I bought my ASUS TUF F15 (FX506LH) since the end of 2021, somehow on a night when I was browsing through YouTube I heard a weird noise from the fan. So I suspected that the fan was broken but I decided to leave it as I thought it wouldn’t affect the laptop performance but few days ago when I was playing with valorant the fan started like buzzing and crackling and my fps went really low down. So I quickly close the game and I went to the armoury crate to check on the temperature and the fan speed and I found that the CPU temperature was around 90+ degree Celsius and the CPU fan speed was showing 0RPM. So I quickly close my laptop and I ordered a brand new CPU fan online and I replaced the CPU fan by my own but somehow after replacing the CPU fan the Rpm of the CPU inside the armoury crate is showing 0RPM again and the temperature remains at 90+ degree Celsius. So I went through browser searching for ways and I found a solution which is to uninstall and reinstall my armoury crate but that doesn’t work and I can clearly see both of the GPU and CPU fan are running but it just don’t expel the hot air out from the ventilators and the RPM is still showing 0 in the armoury crate. Anyone help pls, idk what to do now
0 REPLIES 0
