03-07-2025 02:10 PM
Hi guys i upgraded from air cooler to liquid cooler (before aio installaton 1st slot was working) and after that my tuf b650m wifi mobo is not detecting my m2 ssd i tryed everything at bios and result is 0 meanwhile the second slot of m2 ssd is working fine with same m2 ssd not any problem at all, should i retrun the mobo to store or you guys can tell me any solution please!?
