04-19-2024 04:34 PM
Hi all,
I have a custom water cooled pc with I9-9900k on an Asus Strix Z390-H motherboard.
Currently i have 4x8gb rams on it. I need min 128gb ram due to running some LLM models on it.
Z390-H manual says max 4x16gb rams are supported. Is this true? Can’t I just install a 1x32gb ram in there ? Did anyone tried increasing the ram capacity beyond 16gb single sticks?
04-24-2024 10:56 PM
Yes, you are right! But still uncomfortable about why they write max 64gb ram 😞 . So It does not even give more pcie lanes, its just an additional slot, and therefore should not affect the total max ram ? right ? Maybe I should not even draw generalisations like these as an end user haha 🙂 Do you think that it's safe to go with 128gb ram ? It says that you are a moderator. Do you guys do technical recommendations ?
04-24-2024 11:16 PM - edited 04-24-2024 11:17 PM
Correct, the pcie lanes/slots don't affect the memory.
Since 128GB is on G.Skill's QVL list, you can be sure it's compatible.
I don't see the 2666MHz memory kit, but I do see a 3200MHz kit at amazon which is also on the G.Skill QVL for the ROG Strix Z390-H Gaming motherboard.
You have the i9-9900k cpu which has the strongest memory controller of the 9th Gen cpu's.
