06-15-2023 06:36 AM
The problem that I have with my laptop is that the date and time are reset in the bios (te settings are not lost), and it takes too long to turn on, once the device is on it works fine. I already tried removing the devices (nvme, ram sticks, etc.), reset the bios, use a previous version of the bios with no luck. From what I could see on the web, this problem could be for a dead or broken cmos battery, but I culdn't find it. Does anyone know if this model has a cmos battery? Thank you
