ASUS ROG Strix B550-E Gaming Addressable RGB Issues
kati_albers
I just got done with my first pc build and I am having issues with getting the case addressable RGB to work 100% of the time through Aura. I and using a Be Quiet Pure Base 500DX and there are two LED stripes that can either be addressable to just set to one of the baked in settings. When I am using the addressable option in Aura the front strips will only light up about the top third, this happens intermittently when the system is shut off. After a power cycle it usually corrects. Both LED strips work. I am running the latest update on Armor Crate. There is never any issues with the RGB on the ram or cooler. I just recently checked the RGB plugs and they are in the headers all the way. I am using a ASUS ROG Strix B550-E Gaming mother board, full build specs below.
ASUS ROG Strix B550-E Gaming mobo
Ryzen 9 3900x
AMD Radeon 8490
32gb ddr4 3600 gskill Trident Z
1 TB WD Black sn750
4 TB WD Black Performance Internal Hard Drive
Corsair rm850x
0 REPLIES 0
