Asus ROG RYUJIN III 360 ARGB fans stopped spinning
ZedSly
The other day, I noticed that the 3 fans on the radiator stopped spinning, resulting in an increase in processor temperatures. The pump was still running because I hear it. The first thing I did was to reinstall Armory Crate, thinking it was a software error but without success.
The next step was to check all the connections of the cooler to see if there is any problem on the power supply side, but also after reconnecting all the plugs, the fans still don't spin.
In the end, I changed the magnetic cable that feeds the three fans (initially it was the female one), now I moved to the male cable (came as an alternative in the box) and now its working again. My concern is that I don't know if it is a defect in the cable and in time the other cable will also fail. The female cable doesn't show any sign of damage or burns. When I tried the female cable with just one fan, the fan was trying to spin but it didn't seem to have enough power.
Does anyone have any idea what it could be or have encountered this problem before?
0 REPLIES 0
