04-10-2019 08:36 AM - last edited 3 weeks ago by ROGBot
04-10-2019 09:11 AM
04-10-2019 12:54 PM
04-10-2019 12:56 PM
S4lticid wrote:
I've never used an AIO, only custom loops, but a few thoughts:
Never use stock TIM. Especially pre-applied to a new cooler you're supposed to install yourself. My only exceptions are thermal pads on appropriate components unless temps indicate they need replacement, and if 'stock' means the manufacturer gave me a separate package of paste to apply myself and I know it's a good brand. I even open new pre-built machines and re-paste CPUs and GPUs, and I always see an improvement.
A push-pull configuration on that rad is completely unnecessary overkill and unless your fans are matched and you're sure they're synced on each side of the rad, it's possible you could be causing more problems than helping. Get rid of a set of fans and see if it helps.
As already mentioned, you can't expect to necessarily reach the temps on those reviews as your own local conditions may be different. What is the ambient temperature in the room you're in? The temperatures you can reach are going to be limited by this.
04-10-2019 01:06 PM
Itzycharles wrote:
correct, but the asus aio comes with noctua thermalpaste, i can confirm that. i am saving to get one. since i all ready test a loop, basic and is the same at 3000rpm.
04-12-2019 03:21 AM
Itzycharles wrote:
I am reading you post. You are right. MOST reviewers have ambient temps on the 20-24C. You can not go below ambient temp. on normal ways.
If you have 40-42c with no oc, your ambient temps are between 35to37C. In my case, in idle my temps are 38C with 1000rpm fans. so should bo now on 30ish 31C.
Check, using hwinfo64 what are the temps there.
04-12-2019 08:41 AM
DarkShadow wrote:
That does that mean !!
04-13-2019 08:06 AM
04-10-2019 07:56 PM
DarkShadow wrote:
Recently I just upgraded to ASUS ROG Ryujin 360 CPU Cooler. I am using Asus ROG Maximus X Hero with Intel Core i7 8700K. After installing the cooler perfectly, the stock CPU temperature shows 40 - 42 degree C without overclocking. But as I seen some reviews online/Youtube with the same Motherboard & CPU, temperature should be 25 - 30 degree C Beside I installed 2500 RPM Fan both side of the Radiator for push & pull airflow. I did not use any other thermal paste as ASUS ROG Ryujin 360 came with pre installed thermal paste.
Previously I used Corsair H100i GTX 240. In stock ideal temperature was 46 - 48 degree C. Then whats the point to upgrading 240 to 360 Cooler !!
I am really confused !!! Need Help from Experts.
04-12-2019 02:21 AM
