hi,
I'm currently building a dual loop using the asus rog rampage VI extreme omega x299 with two EK-Quantum Kinetic TBE 300 D5 PWM
looking in the manual it says when using the 2 dedicated pump headers W_PUMP+1 / W_PUMP+2 pumps will be running at 100% , could anybody please tell me is There a way i can control the pump speed
Am i correct in thinking if i connect both pumps one via CPU_FAN and second via CPU_OPT i could control the pump speed this way
would really prefer to keep them both to the dedicated headers if there is some way to do this in the bios
Sorry if this is obvious its my first build and just want to make sure I'm on the correct lines
Any advice be very much appreciated
Thanks
