10-15-2020
11:47 PM
- last edited on
03-05-2024
07:36 PM
by
ROGBot
10-16-2020 05:11 PM
10-19-2020 04:34 AM
Darigitin wrote:
So looking at your mobo there appears to be four RGB headers, two of which are addressable. One addressable is located at the top of the board on the right of the ram slots and the other is located on the bottom left to the right of the front panel IO pins. The Ryuo uses a usb 2.0 connector to control the RGB and the Thor uses a addressable RGB header. So you should be able to connect both on your board and the lower header would probably be the best bet.
I would ask though what you are running that you want to go all the way to a 1200w psu. Asus also sells a 750 and 850 watt Thor, with the 750 not having RGB.
