ASUS ROG Maximus Z690 Extreme Issues - HELP!
tcmathews
Hey Everyone,
I need some help, advices, and guidance. I have been pulling my hair out on this one and I need some insight as to what to try for those who have this motherboard. I built this computer from new, using Windows 11. I have had nothing but crashes, errors in the event log. I have had memory issues. I have replaced the motherboard twice now and ASUS now wants me to send it in AGAIN. So if I send it back to the retailer to be replaced again, this will be the 3rd time. I am sorry, but three motherboards that ASUS says is bad in a row, is there a defect on this board that I/WE dont know about? ASUS tech support has been no help other than wanting me to send the boards back to be repaired. I have noticed that ASUS has removed this board from their site as being available in their lineup.... since this post.
Error's I am getting:
1. Session "NT Kernel Logger" failed to start with the following error: 0xC0000035
2. Session "dc3a3596-71e1-45a3-b2ea-39ad5322fe51" failed to start with the following error: 0xC0000022
3. Session "PerfDiag Logger" failed to start with the following error: 0xC0000035
4. Faulting application name: SystemSettings.exe, version: 10.0.22000.708, time stamp: 0x27a6d211
Faulting module name: ControlLib.dll, version: 1.0.88.0, time stamp: 0x626a4ea7
Exception code: 0xc0000005
Fault offset: 0x0000000000008f8a
Faulting process id: 0x49ac
Faulting application start time: 0x01d87dbf8e046990
Faulting application path: C:\Windows\ImmersiveControlPanel\SystemSettings.exe
Faulting module path: C:\Windows\SYSTEM32\ControlLib.dll
Report Id: 853937b2-f705-49ce-af3e-353e0083c926
Faulting package full name: windows.immersivecontrolpanel_10.0.6.1000_neutral_neutral_cw5n1h2txyewy
Faulting package-relative application ID: microsoft.windows.immersivecontrolpanel
5. Faulting application name: dwm.exe, version: 10.0.22000.1, time stamp: 0x7cbe2305
Faulting module name: dwmcore.dll, version: 10.0.22000.708, time stamp: 0x920c2cab
Exception code: 0x8898008d
Fault offset: 0x000000000011ea0e
Faulting process id: 0x30a0
Faulting application start time: 0x01d87ce9f2a2ae39
Faulting application path: C:\Windows\system32\dwm.exe
Faulting module path: C:\Windows\system32\dwmcore.dll
Report Id: bf7f6584-1c6e-4c79-85bb-008e3e6a4ef7
I am running the following:
Windows 11 Pro
ASUS MAXIMUS Z690 EXTREME w/ Bios 1505
12TH GEN INTEL CORE I9-12900KS, 3.4Mhz
Corsair Dominator Platinum RGB DDR5 64GB (2x32GB) 5200MHz C40 Intel Optimized Model: CMT64GX5M2B5200C40
(3) SAMSUNG 980 PRO 2TB SSD M.2 NVME DRIVES
(2) SAMSUNG 980 PRO 1TB SSD M.2 NVME DRIVES IN DIMM.2 RISER
I am at a loss, have reinstalled windows 11 4 times, same results, have installed windows 10 dual boot with the kernal errors still showing.
Any Ideas, thanks!
18 REPLIES 18
ahfoo
Your memory may be the cause. List your hardware here so as fellow member may try to help.
What is the best way to list my hardware? Not sure if this is right, but I listed this from CPUID. Also, what is odd, is I can run benchmarks all day long in 3DMark, PCMark10 and such and pass with not one error or crash. Gigabyte wants to replace the card as of the email I received yesterday.
Chipset
Northbridge Intel Alder Lake rev. 02
Southbridge Intel Z690 rev. 11
Bus Specification PCI-Express 5.0 (32.0 GT/s)
Graphic Interface PCI-Express
Memory Type DDR5
Memory Size 64 GBytes
Channels Quad
Memory Frequency 2000.4 MHz (1:20)
CAS# latency (CL) 32.0
RAS# to CAS# delay (tRCD) 32
RAS# Precharge (tRP) 32
Cycle Time (tRAS) 63
Bank Cycle Time (tRC) 95
Row Refresh Cycle Time (tRFC) 320
Command Rate (CR) 2T
Uncore Frequency 3600.8 MHz
Memory Controller Frequency 1000.2 MHz
Host Bridge 0x4660
Memory SPD
DIMM # 1
SMBus address 0x51
Memory type DDR5
Module format UDIMM
Module Manufacturer(ID) Corsair (7F7F9E0000000000000000000000)
SDRAM Manufacturer (ID) Micron Technology (2C00000000000000000000000000)
Size 32768 MBytes
Max bandwidth DDR5-4000 (2000 MHz)
Channels 2
Part number CMT64GX5M2B5200C40
Nominal Voltage 1.10 Volts
EPP no
XMP yes, rev. 3.0
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 22.0-22-22-44-66 @ 1375 MHz
JEDEC #2 26.0-26-26-52-78 @ 1625 MHz
JEDEC #3 28.0-28-28-56-84 @ 1750 MHz
JEDEC #4 30.0-30-30-60-90 @ 1875 MHz
JEDEC #5 32.0-32-32-64-96 @ 2000 MHz
JEDEC #6 36.0-32-32-64-96 @ 2000 MHz
XMP profile XMP-5200
Specification Profile 1
VDD Voltage 1.250 Volts
VDDQ Voltage 1.250 Volts
VPP Voltage 1.800 Volts
Memory Controller Volt. 1.200 Volts
Min Cycle time 0.384 ns (2600 MHz)
Max CL 40.0
Min tRP 15.36 ns
Min tRCD 15.36 ns
Min tRAS 29.57 ns
Min tRC 44.93 ns
XMP timings table CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
XMP #1 22.0-22-22-43-65-n.a @ 1432 MHz (1.250 Volts)
XMP #2 26.0-26-26-51-77-n.a @ 1692 MHz (1.250 Volts)
XMP #3 28.0-28-28-54-82-n.a @ 1822 MHz (1.250 Volts)
XMP #4 30.0-31-31-58-88-n.a @ 1953 MHz (1.250 Volts)
XMP #5 32.0-33-33-62-94-n.a @ 2083 MHz (1.250 Volts)
XMP #6 36.0-36-36-70-106-n.a @ 2343 MHz (1.250 Volts)
XMP #7 40.0-40-40-77-117-n.a @ 2600 MHz (1.250 Volts)
XMP #8 42.0-40-40-77-117-n.a @ 2600 MHz (1.250 Volts)
XMP #9 46.0-40-40-77-117-n.a @ 2600 MHz (1.250 Volts)
DIMM # 2
SMBus address 0x53
Memory type DDR5
Module format UDIMM
Size 32768 MBytes
Channels 2
EPP no
XMP yes, rev. 3.0
AMP no
Max CL 40.0
Min tRP 15.36 ns
Min tRCD 15.36 ns
Min tRAS 29.57 ns
Min tRC 44.93 ns
Hardware monitor Nuvoton NCT6791D
Voltage 0 5.00 Volts [0x7D] (+5V)
Voltage 1 3.31 Volts [0xCF] (+3.3V)
Voltage 2 12.10 Volts [0x7E] (+12V)
Voltage 3 0.06 Volts [0x7] (VIN3)
Voltage 4 1.79 Volts [0x70] (VIN4)
Voltage 5 0.75 Volts [0x55] (VCORE)
Voltage 6 1.05 Volts [0x83] (VIN6)
Voltage 7 0.90 Volts [0x38] (VIN7)
Temperature 0 36 degC (96 degF) [0x24] (Mainboard)
Temperature 1 34 degC (93 degF) [0x22] (CPU)
Temperature 2 36 degC (96 degF) [0x24] (TMPIN2)
Temperature 3 35 degC (95 degF) [0x23] (TMPIN3)
Temperature 5 25 degC (77 degF) [0x19] (TMPIN5)
Temperature 6 0 degC (32 degF) [0x0] (TMPIN6)
Fan 7 65280 RPM [0xFF00] (Chassis #7)
Register space PMIO, base address = 0x0A00
Drive 0
Device Path \\?\scsi#disk&ven_samsung&prod_ssd_850_pro_1tb#4&e91be7&0&040000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Name Samsung SSD 850 PRO 1TB
Revision EXM04B6Q
Serial S252NX0H607240E
Capacity 953.9 GB
Type Fixed, SSD
Bus Type SATA (11)
Features SMART, TRIM
Controller Serial ATA Controller - AHCI at bus 0, device 23, function 0
Volume d:\, 953.9 GBytes (100.0 percent available)
Drive 1
Device Path \\?\scsi#disk&ven_samsung&prod_ssd_850_pro_1tb#4&e91be7&0&050000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Revision EXM04B6Q
Serial S252NX0H607247Z
Capacity 953.9 GB
Type Fixed, SSD
Bus Type SATA (11)
Volume e:\, 953.9 GBytes (50.1 percent available)
Drive 2
Device Path \\?\scsi#disk&ven_samsung&prod_ssd_850_evo_1tb#4&e91be7&0&060000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Name Samsung SSD 850 EVO 1TB
Revision EMT03B6Q
Serial S3PJNB0J802555K
Capacity 931.5 GB
Type Fixed, SSD
Bus Type SATA (11)
Volume f:\, 931.5 GBytes (39.5 percent available)
Drive 3
Device Path \\?\scsi#disk&ven_samsung&prod_ssd_850_evo_1tb#4&e91be7&0&070000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Revision EMT02B6Q
Serial S2RENX0J207881L
Capacity 931.5 GB
Type Fixed, SSD
Bus Type SATA (11)
Volume g:\, 931.5 GBytes (35.5 percent available)
Drive 4
Device Path \\?\scsi#disk&ven_nvme&prod_samsung_ssd_980#5&4447ce7&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Name Samsung SSD 980 PRO 2TB
Revision 5B2QGXA7
Serial S6B0NL0T507956T
Capacity 1863.0 GB
Type Fixed, SSD
Bus Type NVMe (17)
Features
Controller NVM Express (NVMe) Controller at bus 2, device 0, function 0
Link Speed PCI-E 4x @ 16.0 GT/s
Volume h:\, 1863.0 GBytes (91.0 percent available)
Drive 5
Device Path \\?\scsi#disk&ven_nvme&prod_samsung_ssd_980#5&38974d8e&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Revision 5B2QGXA7
Serial S6B0NG0RA33233L
Capacity 1863.0 GB
Type Fixed, SSD
Bus Type NVMe (17)
Features
Controller NVM Express (NVMe) Controller at bus 3, device 0, function 0
Volume c:\, 1862.3 GBytes (86.3 percent available)
Drive 6
Device Path \\?\scsi#disk&ven_nvme&prod_samsung_ssd_980#5&20da63d3&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Name Samsung SSD 980 PRO 1TB
Revision 5B2QGXA7
Serial S5P2NG0NC04258V
Capacity 931.5 GB
Type Fixed, SSD
Bus Type NVMe (17)
Features
Controller NVM Express (NVMe) Controller at bus 4, device 0, function 0
Volume i:\, 931.5 GBytes (98.5 percent available)
Drive 7
Device Path \\?\scsi#disk&ven_nvme&prod_samsung_ssd_980#5&ebd909b&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Revision 5B2QGXA7
Serial S5P2NG0NC12311D
Capacity 931.5 GB
Type Fixed, SSD
Bus Type NVMe (17)
Features
Controller NVM Express (NVMe) Controller at bus 6, device 0, function 0
Volume j:\, 931.5 GBytes (98.3 percent available)
Drive 8
Device Path \\?\scsi#disk&ven_nvme&prod_samsung_ssd_980#5&7fad341&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Revision 5B2QGXA7
Serial S6B0NG0RA32717M
Capacity 1863.0 GB
Type Fixed, SSD
Bus Type NVMe (17)
Features
Controller NVM Express (NVMe) Controller at bus 117, device 0, function 0
Volume k:\, 1863.0 GBytes (91.5 percent available)
Graphics
Number of adapters 2
Graphic APIs
API D3D
API NVIDIA I/O
API NVIDIA NVAPI
API Intel I/O
API Intel oneAPI
Display Adapters
Display adapter 0
ID 0x10B0102
Name NVIDIA GeForce RTX 3080
Board Manufacturer GIGABYTE Technology
Revision A1
Codename GA102
Core family 0x172 (GA102-A)
Cores 8960
ROP Units 96
TM Units 560
RayTracing Cores 70
Tensor Cores 280
Technology 8 nm
Memory type GDDR6X (Micron)
Memory size 12 GB
Memory bus width 384 bits
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x1458)
Model ID 0x220A (0x40A3)
Revision ID 0xA1
Root device bus 0 (0x0), device 1 (0x1), function 0 (0x0)
Performance Level Base
Core clock 1260.0 MHz
Memory clock 9501.0 MHz
Performance Level Boost
Core clock 1830.0 MHz
Performance Level Current
Memory clock 9502.0 MHz
Driver version 31.0.15.1640
WDDM Model 3.0
Display adapter 1
ID 0x4000000
Name Intel(R) UHD Graphics 770
Board Manufacturer ASUSTeK Computer Inc.
Codename Alder Lake GT1
Execution Units 32
Technology 10 nm
PCI device bus 0 (0x0), device 2 (0x2), function 0 (0x0)
Vendor ID 0x8086 (0x1043)
Model ID 0x4680 (0x8694)
Revision ID 0xC
Driver version 30.0.101.1994
WDDM Model 3.0
Win32_VideoController AdapterRAM = 0x40000000 (1073741824)
Win32_VideoController AdapterRAM = 0xFFF00000 (4293918720)
Win32_VideoController DriverVersion = 30.0.101.1994
Win32_VideoController DriverVersion = 31.0.15.1640
Win32_VideoController DriverDate = 05/13/2022
Win32_VideoController DriverDate = 06/06/2022
Monitor 0
Model DELL S2721DGF (Dell Computer)
ID DEL41D9
Serial 1J419H3
Manufacturing Date Week 10, Year 2022
Size 27.2 inches
Max Resolution 2560 x 1440 @ 59 Hz
Horizontal Freq. Range 250-250 kHz
Vertical Freq. Range 48-165 Hz
Max Pixel Clock 650 MHz
Gamma Factor 2.2
Monitor 1
ID DEL41D9
Serial 4J419H3
Size 27.2 inches
Gamma Factor 2.2
Monitor 2
Model DELL G3223D (Dell Computer)
ID DELD138
Serial JBF7XG3
Manufacturing Date Week 2, Year 2022
Size 31.7 inches
Gamma Factor 2.2
Software
Windows Version Microsoft Windows 11 (10.0) Professional 64-bit (Build 22000)
DirectX Version 12.0
Silent_Scone
Super Moderator
Sounds like instability.
Return to optimised defaults and retest the system. This includes no XMP or overclocking of any kind. Once confirmed, post up and we will see what we can do to dial things in.
Running defaults on the boards, absolutely no over clocking on the system at all. I have even disabled all that I could find. Ram is Corsair Dominator 64gb, 2x32 dimms. I am on my 3rd motherboard, 3rd set of memory as well. Have reinstalled windows from fresh each time. This is from a Corsair report they had me send in. What is the best way to list my hardware, is there a utility I can run and save for you?
Elgato Windows Reporter (X86)
Product version: 1.00.49.49
PC System type: Desktop
System type: x64-based PC
OS version: Microsoft Windows 11 Pro 64-bit (10.0.22000)
Language: English (United States)
Username:
Internet Explorer: 9.11.22000.0
WebBrowser control: 11.0.22000.652
System score: 9.5
Processor: 9.5
Memory (RAM): 9.5
Graphics: 9.9
Gaming graphics: 9.9
Primary hard disk: 9.8
Mainboard manufacturer: ASUSTeK COMPUTER INC.
Mainboard model: ROG MAXIMUS Z690 EXTREME
Mainboard BIOS manufacturer: American Megatrends Inc.
Mainboard BIOS name: 1505
Mainboard BIOS SMBIOS version: 1505
Processor name: 12th Gen Intel(R) Core(TM) i9-12900KS
Processor cores: 16
Processor logical cores: 24
Processor maximum clock speed: 3400 MHz
Physical memory: 63.72 GB - Corsair CMT64GX5M2B5200C40
Memory speed: 4000 MHz
Graphics name: NVIDIA GeForce RTX 3080
Graphics processor: NVIDIA GeForce RTX 3080
Graphics memory: 4095.00 MB
Graphics driver: 30.0.15.1640
Soundcard name: USB Audio Device
Soundcard name: CORSAIR ST100 Headset Output
Soundcard name: NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
Soundcard name: NVIDIA High Definition Audio
Soundcard name: Realtek USB Audio
Soundcard name: Sonic Studio Virtual Mixer
Monitor count: 3
Monitor size: 1920x1200
Monitor virtual size: 6400x1440
Controller name: [00000001] Intel(R) Ethernet Controller (3) I225-V
MAC Adress : 50:EB:F6:BC:69:94
Active power plan: Balanced
Dim display after: 585
Turn off display after: 600
Advanced Color quality bias: 1
Console lock display off timeout:60
Adaptive display: 0
Allow display required policy: 1
Display brightness: 75
Dimmed display brightness: 50
Enable adaptive brightness: 0
Remove the CPU cooler and CPU whilst checking for bent pins, then reattach cooler whilst making sure mounting pressure is even.
Not CPU, Socket, or pins. Been testing for over a week. I did replace the GPU, and for a week now, no errors thus far. When I emailed Gigabyte, they immediately replied RMA the card from the errors presented and didnt even want to troubleshoot. I appreciate all the advice and insight in this from everyone.
Hello,
Sorry, we were all under the assumption you were still troubleshooting. Glad the GPU resolved it for you.
No problem, I really appreciate the help and insight in all to look at. I do still get the following error about every 4-7 days.
Fault bucket 1925935670592082795, type 5
Event Name: MoAppCrash
Response: Not available
Cab Id: 0
Problem signature:
P1: windows.immersivecontrolpanel_10.0.6.1000_neutral_neutral_cw5n1h2txyewy
P2: praid:microsoft.windows.immersivecontrolpanel
P3: 10.0.22000.708
P4: 27a6d211
P5: ControlLib.dll
P6: 1.0.88.0
P7: 626a4ea7
P8: c0000005
P9: 0000000000008f8a
P10:
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.79ec4763-c3b4-4f3e-8206-063c2297cdee.tmp.mdmp
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.2c3d7e5f-870f-42b7-9af0-c140db9985f1.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.27518368-9c85-4f42-bd63-300ea5d1ccdb.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.e6f9a51f-d61f-4818-8d27-b4e3d5b72f22.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.737b4b6c-86ca-414b-8757-8926e2956e50.tmp.txt
These files may be available here:
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_windows.immersiv_7413d8965e79c71df513da6417716b8f7233742_06ae74d7_ed77dab9-3962-4152-9de4-84dbc0239a25
Analysis symbol:
Rechecking for solution: 0
Report Id: ece47089-9cd4-460d-8509-615a683c7cf0
Report Status: 268435456
Hashed bucket: 8e29035ae962a1671aba4c49d1e5136b
Cab Guid: 0
Faulting process id: 0x52e4
Faulting application start time: 0x01d88fe3e0c426d0
Report Id: c48ba96e-ee52-4bf0-af38-44cc77283d36
Hello,
ahfoo
Try updating your Nvidia driver, choose option to perform clean installation. Hope it help.
