So I got a new motherboard and a new CPU, after building for the first time I got a q-code of 00 there was no boot and therefore no post. After much searching, contacting ASUS and Amazon, it seemed as if one of the components was faulty. So I got a replacement for both, but same issue happened again. The chances for these components to be faulty again are astronomically low, so the issue must be with something else.
I have Corsair AX860 PSU, and it works perfectly fine with my old ASUS P9X79 + i7 3820k components (which I'm using right now)
Am I plugging in something wrong? Using the same power cable that powers my old CPU and Motherboard. I tried different cables for the CPU and different slots on the PSU. I only have the 1 motherboard cable, but like I said, all these were perfectly fine powering my old PC, even when I rebuilt it after the first Maximus + i9900k failure.
Is there anything else that might be causing this?
