Hiya,
I recently acquired an ASUS ROG Maximus XI Gene and noticed there's a
Node connector on the side of the board.. It looks similar, if not identical to the one found on the Rampage Encore board, which allows you to use it's included
Fan Extension Card II. I was therefore wondering would it be possible to make it work?
I have tried to plugging in a spare Fan Extension Card II board from an Encore but none of software or utilities for the Maximus XI Gene recognise it. Any fans plugged into this expansion board seem to run at a minimum speed... What am I missing?
ASUS ROG RVIE Encore| i9-10940x | Dominator Platinum 128GB 3333 MHz | EVGA RTX 2080 Ti SLI | Samsung 970 Pro 1TB NVMe (x3)
WD Black 4TB | WD Black 6TB x2 | EVGA 1600 P2 | CaseLabs SMA8 | Custom Water Cooling | HWLabs Black Ice Nemesis GTX 560
XSPC RX 480 v3 | XSPC D5 Vario x2 | EK Blocks | EK-RES X3 400 | BitsPower Fittings | GentleTypoon 1850 x12 | Corsair SP140 x8 | Lamptron CM615
Twitch.tv/MsNikita | Twitter.com/MsNikitaTV | Instagram.com/MsNikitaTV | Reddit.com/r/MsNikitaTV
