ASUS ROG Maximus XI Extreme LED's
ianmit
On the ASUS ROG Maximus XI Extreme, how do I turn off RGB lighting and leds aound rear sockets when the machine is powered down ?
I have tried settings in the BIOS, but they dont match the manual.
For example p 3-19 of the user manual Para 3.6.8 states:
"When system is in sleep, hibernate or soft off states
This item allows you to turn the RGB lighting on or off when the system is in sleep, hibernate or soft off states.
Configuration options: [On][Off}"
I can't find this in the latest BIOS v 1401, maybe someone could point me to it.
Cheers
Ian
fatfatty
Hey Ian,
Setting up my new rig with the XI Code, and assume bios mostly the same. To find those options, get into Advanced mode (not EZ, change with F7 hotkey).
In Advanced bios mode, click on the Advanced tab on the top section, under that look for Onboard Devices Configuration. Those options you are looking for should show under that...they do for me.
Hope this helps - D
