Asus rog matrix hd7970 fan problems
ettorelandolfi
Hello to everyone,as another user tell on this topic:
https://rog.asus.com/forum/showthread.php?88571-7970-Matrix-Platinum-Fan-Control-Only-1-works-GPUTwe...
I also have the same issue with my board,so only one fan spin with thermal regulation and the second stays at 20%.Also with afterburner or other software only one fan can be regulated,the second stays at 20%.I have tried in the same system with an asus hd 7970 direct cu II and the two fans are controlled very well with afterburner or with the Drivers utility,with no problems.
My systems specs:
Mobo Gigabyte m68mts2
8gb kingston 1600
Psu Vultech 850w
0 REPLIES 0
