Asus ROG Huracan audio issue sound noise
bigwati0
I've bought recently Asus ROG Huracan G21-CX and I have a problem with audio. There is some noise in the front panel (headphones). It doesn't depend on volume. Sometimes it's stronger when I use mouse. I've read about some similar issues and cannot find simple solution (blame on cables, motherboar, usb ports etc). Back panel is okey untill graphic card is heavily used, than I hear other noise (like a fan noise?).
Is this common problem in this model? Is there any solution?
My idea is to buy a usb sound card and maybe it will help. Also heard about mass loop filters but don't know if it could help.
Is there a way to plug headphones to usb-c port?
0 REPLIES 0
