asus rog crosshair x670e extreme - AE9 Soundcard
GoldenChallis
Hi All,
Just getting around to update my Rampage V 2011 motherboard, and moving over to
asus rog crosshair x670e extreme, noticed a lot has changed over the years. less Sata, less PCIE
however more M.2s
Question : does the x4 slot on the mobo support soundcards? Have a ae9 soundblaster I plan on using.
Regards
AS185
Hey,
It should work just fine 🙃 Awesome soundcard by the way 👀
