01-26-2026 01:01 PM
Hello all, I have recently purchase a lian li lancool 217 case to pair with my rampage V extreme motherboard.
The lian li has a front panel connector that doesn't line up with the front panel pins on my Asus rampage v extreme motherboard.
Im wondering if there is a solution to this problem as I'm guessing it's quite common or if there's a conversion kit / work around. Many thanks in advance
rampage V extreme pinout
Lian li front panel pinout
02-01-2026 01:43 PM
Hello killaklik
The ROG Rampage V Extreme comes with a Q-Connector, you can use that instead of your case's connector.
Check in the motherboard accessories.
