Hello
I purchased the asus pg279q 165hz monitor 6 months ago and have been having increasingly frequent disconnects. The monitor randomly blacks out and looses signal. It's becoming more frequent and it seems to me that the connection between the monitor and the wire is the problem. I have to hold the display port cable at a very specific angle to get signal. If it's this bad now then i'm sure it will only get worse...
I have tried a new display port cable, reinstalling drivers etc with no luck. Should I return the monitor as faulty under warranty?
Super annoying as the monitor is amazing bar some mild back light bleed.
Any info would be greatly appreciated.
