Asus P8Z77-V Premium post code 15
gendalf
Dear all,
I have this MB in the computer for a long time and approximately every 2 years the PC ends up with post code 15, so it does not boot. The only available solution (I have tried booting with one stick if RAM placed in 1st slot, checked the pins of CPU, unassembled the PC and reassembled it several time) is to send it for the RMA, where according to the protocol they just reflash the bios and it works for another two years.  I have done this 3 or 4 times already and I wonder if there is anything else I can try. The last time this happened I have done the BIOS Flashback procedure, which probably worked well, at least according to the manual, but the cone 15 is still there. This computer is good enough for what it is used so I do not want to buy a new one. Any ideas would be of help.
Thanks a lot
0 REPLIES 0
