Asus Maximus VIII Extreme problems with strix 1080 ti
gianni0610
i tried to install my new Asus 1080 ti strix on my system with motherboard Asus Maximus VIII - bios version 3504, but bios can't show the GPU.
I tried with another PC with Asus 270E and the graphic card work well.
Need help. Is not compatible Maximus Extreme VIII ? I can't believe it!
Thanks
gianni0610
No answers!
:confused:
kkn
Level 14
it is compatible.
did you plug all cables ( pci-e ) in to the GPU?
and pluged the GPU in 1'st pcie slot where it should be placed? ( read manual )
kkn wrote:
it is compatible.
Of course. The GPU isn't recognize by Bios. Tried also with other GPU on Mb as ASUS 1060 *and this one work properly.
As some bios versione at all.*It's the same. No found the strix 1080ti asus
