Asus extreme z390-Not fit_ View 71
ssaa
I took off the i/o shield, so it fits now. But its hard to run cable management. Because Board block the holes in case that wire go tho.
dayjob
I have the same board and case and problem. You just need to live without the rubber guards and running cable is a pain in the ass due to the size of the board.
bro my cable management is a crab, like a spaghetti smashed into case it's horrible
