Asus Crosshair VIII Formula Sensor reporting
oatfedgoat
I'm trying to configure fan curves in non Asus software (Corsiar iCue) and I am struggling to identify which sensor number I need to select for the CPU.
iCue reports the sensors in this format:
asustek computer inc. rog crosshair viii formula temp #1
asustek computer inc. rog crosshair viii formula temp #2
etc
Is there somewhere that lists what each # is a sensor for or does anyone know which # is the CPU please?
The reason for using two different pieces of software to control fan profiles is that there are a total of 16 fans in the PC and having them managed differently also helps redundancy on the push/pull of the radiator in case one software fails/crashes.
0 REPLIES 0
