ASUS Crosshair V Formula Motherboard
Dark
Hiya all im new 1st of all i'm called Kaitlin.
I have just got myself the ASUS Crosshair V Formula Motherboard and 16Gig of Gskillz Mem.
Ok after reading some post's on forum i have seen users have had problems with cpu for the Mb.
So my question is what Cpu should i get for it as seen post's saying pc wont boot extra n cost is not a problem seems im build'ing pc bit by bit. Thank's Kaitlin.
motherboard ASUS Crosshair V Formula
PSU Fractal Design Newton R2 1000W
MemoryRipjaws 16 GB
CaseArmor Mx
CPUAMD Bulldozer FX-8120 8 Core 3.10GHz
Clocked to 4.5GHz
Im a girl 🙂 so be nice as i bite
6 REPLIES 6
Homiestar
As long as the BIOS is updated, and the cpu is a compatible socket, which is AM3+, you should have no problem with CPU's
I got my CHVF and the FX-8150 and had no problems, booted up first time! Just make sure you get a big enough power supply to power your build.
Good luck on the build!
Case - Cooler Master Storm Enforcer
Motherboard - Crosshair V Formula
CPU - FX-8150 3.6GHz ( OC'd to 5.4)
CPU Cooler - Corsair H70 (2 gentle typhoon fans)
GPU - ASUS Radeon 6850 HD 1GB
RAM - G.Skill Ripjaw X series (2x4gb) 1600 (OC'd to 1725)
PSU - Seasonic 860w platinum
HDD - Seagate Barracuda 500gb
SSD - Corsair Force Series GT 120 GB
OS - Win. 8 Pro 64 bit
Silver_Wolf
I can support what Homie has said above. I also run a Crosshair V Formula with a FX-8150 and it runs like a charm no issues at all.
wolverine7074
when I got my CHVF it booted just fine with my AM3 cpu and have found with a good power supply and updated BIOS it runs very smooth
Mobo: Crosshair V Formula
CPU: AMD FX-8120 8 Core 3.1 GHz
RAM: 4x4GB Corsair Vengeance 1866 DDR3
VGA: Zotac Nvidia Geforce GTX 550 Ti X2
Optical: Asus DVD Burner Combo Drive X2
SSD: Corsair Force SATA III 120GB
HDD: Seagate SATA III 1TB Storage
OS: Win7 Ult x64 SP1
Cooling: Corsair H100 Hydro CPU Cooler
Case: CoolerMaster CM690 II Advanced
PSU: Silencer Mk II 750 W
DaemonCantor
One little help would be...If in doubt look at the Serial Number next to the BIG 24pin Power connector and the last 4 digits are your BIOS revision and as long as your revision number is Higher than 0705 then your good to go with even the FX CPU's. There are still some boards with 0705 and lower that will need an older AM3 CPU to boot first and flash the BIOS before you can install an FX. the BIOS for the FX line starts at 0813 all the way up to 1402. I would be careful with 1402 for now because there has been reports of instability and one person stated that it Bricked his BIOS.
Ok well after looking at the code near my 24 pin its a 08 so all look's good Glad i got a Amd Mb as i7 chips for intel cost a bomb to fx chips what i can buy at 150+ 🙂 as for graf card mite use my old one in sli mode seems there ok cards ish
MemoryRipjaws 16 GB
CaseArmor Mx
Clocked to 4.5GHz
I can confirm what wolverine7074 saying, I got my CHV and Fx-8150 chip 2 weeks ago, and sadly my pc could not boot with the chip after using nifty old google I found out that i need to update my BIOS. Got a chip from my friend the Athlon™ II(AM3 chip) but you can use the Phenom™ II or Sempron™ 100 Series Cpu's to update my bios. I updated my bios with version 1301 shutdown my pc and pop my fx-8150 in, Booted without any problem:cool:
Board: Crosshair V Formula
CPU: AMD FX-8150 4.74Ghz (19.5*242 1.44V)
RAM: G.Skill 2133 8GB Running @ 1133.2MHz 10-11-10 (1.6V)
PSU: Corsair AX850
GPU: Ati 7950
OS: SSD OCz Agility 3 120GB (Windows 7 64-bit Ultimate)
Cooling: Antec H20 620
Case: Cooler Master HAF 912 Advanced
