Armory Crate causing system instability
-Filtered-
I recently got an Asus TUF laptop (Model: FA507XI) and for some unknown reason, it kept bluescreening. After a bunch of messing around, I just reformated the whole and it stopped bluescreening. Upon further research and testing it seems that if I have armory crate installed it causes the system to crash the video drivers. I have tried all the usual things to fix it (using DDU to uninstall and reinstall drivers, updating drivers, installing Asus offical drivers) and nothing worked. Once I reformated the ssd again because uninstalling armory crate didn't change anything, the machine works just fine. I'm wondering if anyone else has encountered this issue or knows why armory crate would cause my system to become unstable.
From what I can find its the app as a whole. I have Razor Synapse with RGB and it works fine with it. The mini dump files keep pointing to McAfee Anti-virus but I don't even have it installed. I even ran the official McAfee uninstaller and that doesn't work.
