ARGB and asus rog strix b550 f gaming wifi
deusex263
Hello
i built a new PC with an asus rog strix b550 f gaming wifi
i would like to connect 5 ARGB devices on the only one ARGB header on this mobo
i read somewhere that only 4 devices should be connected to a single ARGB header and no more
So i connected only 4 devices using daisy chaining and it works well
i use armory crate software to drive them with AURA SYNC
Is it possible to daisy chain the fifth device without any risk ?
i'm afraid it's too much for one single ARGB header
Moreover the header support 3A max
thanks
DjRavix
deusex263 wrote:
Hello
thanks
it depends on the power draw of the devices ... if the total does not exceed the 3A your fine
if it does you might want to confider A Powered ARGB Hub or an extension cable that Provides power directly from the PSU
You might want to look here for those kind of options:
https://www.asus.com/campaign/aura/global/Partners-and-promotions.php
ASUS Maximus 13 Extreme
Intel i9 11900K
Corsair Dominater Platinum RGB
Phanteks Enthoo Primo
Samsung 980 Pro 1TB
2 X Samsung 980 Pro 2TB
Corsair AX1200I
EK-Velocity D-RGB - Nickel + Plexi
EK-XTOP Revo Dual D5 PWM Serial - (incl. 2x pump)
XSPC RX480 + XSPC RS280
4 X Corsair SP120 PWM OEM Fans
2 X Noctua NF-A14 industrialPPC-2000 IP67 PWM
2 X Noctua NF-A14 PWM chromax.black.swap
2 X Noctua NF-S12A PWM chromax.black.swap
1 X Noctua NF-A15 HS-PWM chromax.black.swap
